Old 10-17-2006, 08:34 PM   #1
aluminum fuel line and 3/8" filter questions
My Ride: 87 GLHS & 73 Cuda
Is 3/8" aluminum fuel line safe to use with the fuel pressure our cars produce?
Also, since I'm going to upgrade all of my supply line to 3/8", what filter should I use that has both 3/8" in and out barbs? (The stock has 3/8 in and 5/16 out I believe)
tvanlant is offline
Old 10-17-2006, 08:55 PM   #2
My Ride: 1987 Daytona ShelbyZ
Engine: 2.2 T2
summit sells the russell brand that is rated to 250 psi but the also sell their own brand that you would have to check with their tech support on. they also sell the summit brand in stainless for 32 bux for 20 ft.
Norm
overboostperformance is offline
Old 10-17-2006, 08:56 PM   #3
Well I've already got aluminum line (unknown brand), so that was why I was asking. Surely if their stuff is rated to 250 psi, then the stuff I have should handle 60-70.
tvanlant is offline
Old 10-17-2006, 09:19 PM   #4
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I just installed 3/8" Summit aluminum fuel line for the feed/return on my Spirit R/T and haven't had any problems with it. You will also need the Summit insulated line clamps to secure them to the underbody.
iTurbo is offline
Old 10-17-2006, 11:13 PM   #5
What about a filter? Is there a filter out there similar to ours with both 3/8" in and out?
tvanlant is offline
Old 10-17-2006, 11:24 PM   #6
I ditched the stock filter setup and used a Russel inline filter that uses 6AN in/out. Filter is now underhood just behind the passenger side motor mount.
iTurbo is offline
Old 10-23-2006, 07:19 AM   #7
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
if you're questioning the generic metal line that comes from parts stores, they're fine for PSI. Think about the brake system? Know how many thousand PSI they take when you slam the pedal? Same metal line material.
DustyR/T is offline
Old 10-23-2006, 07:47 AM   #8
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
aluminum
speeduphoria is offline
Old 10-23-2006, 12:37 PM   #9
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
Actually, brake lines are steel, and can see 2000 psi in a hard stop.
For the filter, I use a GM TPI filter (I can get the number later, if you want) with the -6AN to Saginaw adapters from Summit. That way, I have a $10, 10 micron, EFI safe, filter. The -6AN inline filters from Summit are usually setup for carb applications with a 40 micron filter. You really want 10 microns to keep small particles out of the injectors.
Shel-Game is online now
Old 10-23-2006, 10:58 PM   #10
I'd rather not have to use any AN stuff. Isn't there just a factory replacement filter for any car that had 3/8" in and out?
tvanlant is offline
Old 10-23-2006, 11:09 PM   #11
What about this filter? They don't list how many microns though
https://www.jegs.com/webapp/wcs/stor...tegoryId=27319
tvanlant is offline
Old 10-27-2006, 12:42 PM   #12
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
I don't think those are for fuel injection...
I practice what I preach:
crazymadbastard is offline
Download PC Drivers | Final Fantasy Wallpapers | Nicole Kidman Blog | Mortgage Calculator | Buy Anything On eBay
Page generated in 0.82871 seconds with 13 queries
