Old 10-26-2006, 09:03 PM   #1
Fuel lines... did I hook them up wrong?
My Ride: 86 GLHS
Engine: 2.2 Turbo Intercool
Check out the pic... I 'm am not sure if I hooked this up right... can someone give me some direction, or maybe a diagram?
BLASINTEBO is offline
Old 10-26-2006, 09:56 PM   #2
Yep, you have it backwards, large line goes to the hard pipe, small line goes to the reg. Also, and listen carefully, you have the wrong hose on there, I can see its all swelled up, DO NOT drive with it, it will burst and you'll burn your car to a crisp. You need to specify and buy High Pressure fuel line-see this thread-
http://www.****************/forums/showthread.php?t=8358
Old 10-26-2006, 11:44 PM   #3
Feedback: (32)
Looks like you also have the incorrect hose clamps on it.
Get the FUEL INJECTION hose.
tryingbe is offline
Secured Loans | Credit Cards | Mobile Phone | Bad Credit Mortgages | Mortgage
Page generated in 0.72658 seconds with 13 queries
