Old 11-02-2006, 08:50 PM   #1
+40's and cal questions
My Ride: 88 daytona pacifica
Engine: 2.2, t3/t4 fmic
Ok I am upgrading my mitsu to a 50trim. so Now I am getting +40's and am wondering if a custom cal would elimintae the need for an adjustable FPR?
and how much boost can +40's support? should I be good to 20psi? plan on running about 15 daily, 20psi track and weekends
currently I am running a mitsu intercooled with a 5th injector and a zenor on the map, MBC set to 15psi, 5th injector not comming on yet, but have it set to come on at 15psi but havent tried out how much boost I can add before I start to come out of the rich
I was just going to go with a AFPR but I also want to change rev limiter and speed governer as well
88jbody is offline
Old 11-02-2006, 08:55 PM   #2
Dez
I've ran over 27PSI with my set of +40's and custom cal, never had a problem.
This of course is my daily driver. =)
Dez is offline
Old 11-02-2006, 08:59 PM   #3
perfect that is what i want to here so no aFPR is need right if so then All I need is a spare sbec to socket
88jbody is offline
Old 11-02-2006, 09:57 PM   #4
My Ride: 89 Lebaron TII convt
Engine: 2.2 turbo II
well the comp cant really compensate for that much extra fuel, i was always under the impression that you need an adpr to turn the pressure down, otherwise you will be dumping fuel in at stock pressures with bigger injectors
Beachbum3478 is offline
Old 11-02-2006, 10:02 PM   #5
My Ride: 86' GLH Omni
Engine: 2.5 Turbo
i'm running +40s in my 2.5 omni at 20 psi and it seems to run good..... my af gauge reads well atleast.....
me_2_3_5 is offline
Old 11-02-2006, 10:33 PM   #6
A stock computer can't without the AFPR, but one socketed running a custom cal should I would think? and if not then I add the AFPR
88jbody is offline
Old 11-03-2006, 09:46 AM   #7
yea but even a performance cal cant adjust the actual fuel pressure like you could with an adjustable fuel pressure regulator, think of it this way. is the computer manaully going to turn the knob on the afpr?
Old 11-03-2006, 09:59 AM   #8
Feedback: (32)
Computer adjust the opening and closing pulse for INJECTORS, thus control the amount of fuel.
You don't need the adjustable fuel regulator but you will not be able to fine tune without it.
tryingbe is offline
Old 11-03-2006, 04:13 PM   #9
Dez
Yeah, get an AFPR, it helps. I have one installed along w/ my custom cal.
Dez is offline
Old 11-03-2006, 08:11 PM   #10
ok that was what I was wondering, when I get one should I get a rissing rate AFPR? or just an adjustable one?
88jbody is offline
Old 11-03-2006, 09:11 PM   #11
For the price of an AFPR and a custom cal, you can buy your own burner, a few chips, a couple sockets, and make your own calibration. Then you don't need an AFPR, just adjust the computer.
anonymous_user is offline
Bankruptcy | Debt Consolidation | Halloween Costumes | Debt Consolidation | Mobile Phone
Page generated in 0.35918 seconds with 13 queries
