Old 11-17-2006, 12:44 PM   #1
20+ Injectors
My Ride: '89 Chrysler Daytona
Engine: 2.5L 4 Rocker!
89 2.5L TI No, I/C
I am able to pick up a set of new 20+ injectors for about $130. Now, i have the stock injectors in rite now. What would i have to change for the 20+'s to work?
Thanks
Chris
abiba_69 is offline
Old 11-17-2006, 12:48 PM   #2
My Ride: 87 GLHS & 73 Cuda
You wouldn't have to change anything. They will plug right in. However, with a stock computer and no AFPR, it may run a little more rich. If you are running stock boost levels, you're not going to gain anything from bigger injectors. If you are going to intercool it and up the boost, then the +20s and an AFPR would be good.
tvanlant is offline
Old 11-17-2006, 12:50 PM   #3
Feedback: (32)
Calibration or fuel pressure regulator.
Either way, you're gonna need a wideband to monitor fuel.
tryingbe is offline
Bad Credit Mortgages | Mortgage Loans | Real Estate Investment | MPAA | Bankruptcy
Page generated in 0.31717 seconds with 13 queries
