Old 11-20-2006, 07:12 PM   #1
Peak Inj Circuit Voltage
Code 26:26 Peak injector circuit voltage has not been reached (need to check computer signals, voltage reg, injectors).
89 Tona Shelby TII very stock
Anyone else exprerience this one? Im takin care of possible Voltage Reg with another Nippodenso 120amp Reuild. Then gonna try just cleanin inj connections and ohm out each inj lookin for any fluxuations. Any remedies out there i aughta know about?
Thnx
goforthz28 is offline
Old 11-20-2006, 09:23 PM   #2
My Ride: 1986 Shelby Charger
Engine: 2.2l turbo
Feedback: (-1)
good clean grounds ussually do it...
swiftman is offline
Old 11-21-2006, 04:49 PM   #3
Thks for the reply, any idea of where the Injector circuit gets to ground? the previous owner has so #8 or #10 straps groundin alot of the motor. Thnx again
Old 12-01-2006, 11:18 AM   #4
My Ride: 1985 S/C
Engine: 2.2 turbo 2
that code is usaully caused by the injector connectors or the injector harness. Make sure you can see no green corrosion in connectors or on injectors. you may have to get new injector harness. Shawn
PART # for harness is 4450499 for 1989
still avail from chrysler list at 131.00
HOPE THIS HELPS
ShelbyShawn is offline
Online Loans | Secured Loans | Car Loan | Xbox Mod Chip | Shares
Page generated in 0.31234 seconds with 13 queries
