Old 12-07-2006, 01:51 PM   #1
Strange Timing Curve
My Ride: 1990 Daytona VNT
I have a 90 Daytona VNT(Garret Tll Turbo). First let me say that it runs very good.
The problem I have when under boost(12*), Wide open Throttle and 3200rpm under a load the timing shows 16btdc through the Tech 1a that I have set up for a manual trigger snap shot. I notice the timing backs off as the rpm goes up but only when boost is present. When I back off the throttle slightly I can feel a little more power before it starts to decel. My base timing is 12*. The O2 reads .99 volts (Rich) and the knock sensor is at .oo3(wehre it usually stays) The knock retard remains at 0*. This to me is very wrong. My thought is the computer is misinformed because of the T2 turbo and vac routing.
Anyone else have an idea on what going on here?
matt59 is offline
Old 12-07-2006, 03:17 PM   #2
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
The WOT timing maps are more conservative than the part throttle maps. The reason is, that the computer tries to get close to stoic at part throttle, at WOT it goes by pre-set PW only (for a much richer mixture).
Stoic + advance + boost = boom
Shel-Game is offline
Old 12-07-2006, 05:59 PM   #3
Is there any way to adjust it?
matt59 is offline
Old 12-07-2006, 07:05 PM   #4
Engine: 2.5L T1
Sure, use D-Cal or CHeM to edit the cal and burn your own chip...
Online Image Resizer | Secured Loans | Debt Consolidation | Mortgage | Bankruptcy
Page generated in 0.43358 seconds with 13 queries
