12-23-2006, 10:06 AM
#13
My Ride: 87 GLHS
Engine: 2.2 8Valve
Originally Posted by ACR Turtle
Yes there is a post saying you can use the DSM injectors.
The resistance (ohms) needs to be measured on different injectors to see if there compatable for the vehicle. TD injectors are low ohm, around 2.6. There are some high ohm injectors made as well. Putting a high ohm injector in a TD will work, but will flow less in a TD than a low ohm version of the same flow rate and vice versa. A cal change would be needed to get the full effect of the larger flow rate from the higher ohm injector on a TD. Now putting in low ohm injectors on a vehicle that is designed to run high ohm injectors, will most likely overload the computer and fry it. Same principle as running multiple speakers in parallel and dropping the ohms using an amplifier not designed for it. It can overheat and go into meltdown.
