02-13-2007, 03:09 PM
TI to TII conversion using a TI LM
My Ride: '85 Dodge Daytona Z
Engine: 2.2L TI
I would like to know if it is possible to do a TII conversion but modify it slightly to be able to use the stock TI computer (I have an 85 Daytona). I would use the throttle body from my TI so I could use the 2 wire AIS. I would use a one piece TII intake manifold, TI injectors (except I would use TII injectors for cylinders 1 and 2 since they are programmed to run lean to compensate for the log manifold), and the rest would be the same as you would normally do for a TII conversion. The reason for this is simplicity, cost and I want to use the aggresive spark timing of the G-head calibration verses the mild spark timing for the swirl head from the 86-87 TII LM's.
If I am completely wrong about this, let me know, please. I have read enough to be dangerous but confused is probably a better word for it.
Eventually i would like to use an Eprom burner to modify the chip, so I think I would want the 85 LM for that anyways. I don't want to buy a fancy MP TII computer for now and then wind up using my 85 computer for re-calibrations in the future (waste of money).
