Old 04-01-2007, 08:41 PM   #1
Vacuum line orifices
My Ride: 1986 Dodge Daytona
Engine: 2.5 TBI
Images: 2
I'm going to need to replace all of my vacuum lines and all connectors and orifices.
It is the Orifices that is the point of this question. What size are the orifices? Can they be fabricated and if so what are the specs?
86Tona is offline
Old 04-02-2007, 11:53 AM   #2
My Ride: 87/89 LeBaron Coupe
Engine: 2.5l T-1,Intercooled
The orifaces are re-usable if not broken, if broken, look for the brass insert. It can be glued into a plastic hose splice from the parts store. There are several different sizes used in the cars over the years,don't know the specific #'s, but they were color coded--yellow, lt blue, orange etc. I got a few needed ones by scavenging what was left of vacuum line leftover at the boneyards. I think some may be available at Napa.
vcrpro3 is offline
Old 04-02-2007, 01:24 PM   #3
Engine: 2.5 TBI
Images: 2
Unfortunatly all of the vac lines from my project were distroyed when they removed the head. I bought the car with the engine in pieces. It's been machined and the parts gathered for the rebuild. When it goes in the car I want to do a custom routing of the vacuum lines. I guess I'll check with the dealer or try to locate a turbo engine compartment at the bone yard.
86Tona is offline
Old 04-02-2007, 02:45 PM   #4
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
you can use welding tips as orifices, the size is 0.20 I think. Someone pleasecorrect me if im wrong.
Or you could doa search here for "orifice welding" and I'm sure you'll find what your looking for.
daytonajesse is offline
Old 04-02-2007, 10:20 PM   #5
My Ride: 92 Daytona Iroc R/T
Engine: 2.4 T-III
i guess your talking about the orifice in line to the wastegate? you can find them at pepboys in the help section
Chucksrt is offline
Old 04-02-2007, 10:48 PM   #6
Engine: 2.5 TBI
Images: 2
I would love to locate these but I can't unless I know what size. Making an orifice is as simple as locating a piece of brass the proper diameter and drilling a small hole in it. But what size is the hole? I'm guessing 1/32" or 1/16". I don't think a 0.20 is right because that's 1/5". I think it should be much smaller but I don't know yet.
I know that when I replaced the 'T' connector for my PCV valve I used a 'stock' unit. However it still didn't run right. The actual unit has an orifice in it. This if for my TBI and the orifice is 1/32" or 3/64" in diameter.
So the question is, what size are the three different orifices that I find on the vacuum diagram for the '87 Shelby Turbo Z.
86Tona is offline
Old 04-03-2007, 08:16 PM   #7
Found at CSK in the help section. VACU-TITE! (Dorman) brand, P/N 47311,3/16 inch vacuum restrictor, same size as the ones in the vacuum harness
vcrpro3 is offline
Old 04-06-2007, 07:45 PM   #8
My Ride: 85 GLHT, 87 ShelbyZ
The orifices range in size from .019" to .035" depending on color. Just scour the J-yard for them. Basically all it does for the turbo is make it spool faster. Not really needed. But the J-yard is the best place to find them and where they go exactly.
GLHNSLHT2 is offline
Old 04-09-2007, 01:15 PM   #9
Oops I forgot a zero
Real Estate Investment | Mobile Phone | Remortgages | Hummer | Problem Mortgage
Page generated in 0.35054 seconds with 13 queries
