04-03-2007, 08:18 PM
What color is the smoke?
White with a sweet smell is coolant and probably means a head gasket problem.You may also have a white milky substance in the oil and oil cap,that would be coolant in the oil.
Blue smoke would be oil, could be numerous things,Valve Seals,Internal Engine,I have never seen a PCV System problem cause smoking like you are describing, remove the breather hose from the air box with the engine running,if there is a lot of smoke coming from that hose it is probably an internal problem,you will have to run wet and dry compression test and cylinder leak down test to verify.
Also remove and inspect the spark plugs for oil fouling to determine if it is one or multiple cylinders.
If the smoke is black the vehicle is running extremly rich.
