Old 05-02-2007, 07:56 PM   #1
Charger fuel pumps?
Ok so I understand the chargers have 2 fuel pumps 1 in tank and 1 inline when I replace the pump to a hiflo unit do I just replace the inline pump or the intank or both? I would like to be able to just replace the inline pump as it would the quick and easy but I also want it done right.
darrinb is offline
Old 05-02-2007, 08:32 PM   #2
My Ride: 1987 BMW 325es
Engine: 2.7 I6
Images: 15
Take both off and replace the intank pump. I did this on my charger but the pump i put in it was bad. So took the intank pump out and put an inline pump on the car. So actually you could do either.
Force Fed is offline
Old 05-02-2007, 09:40 PM   #3
so if I run an inline pump do I need to take the intank pump out or can it be used as a booster pump
darrinb is offline
Old 05-02-2007, 11:17 PM   #4
My Ride: 87 Shelby Charger
Images: 8
I think on the dual pump setup, (up to 86), the in tank was only 5 psi , the inline 50-55. In 87 they just went in tank. Just run a 255 intank, then your done...
boost geek is offline
Car Credit | Remortgaging | Free Advertising | Online Advertising | Santa Cruz Hotels
Page generated in 0.40184 seconds with 13 queries
