Old 05-03-2007, 08:50 PM   #1
87 shelby charger no spark
just bought a 87 shelby charger with 9362 miles!! problem it has sat for years.guy had it running a year or two ago.brought it home charged the battery,but cranks but no spark. looking in the service manuals but they dont give me a good break down on if its the logic,power,or the asd relay that could be my problems.turn key on and no voltage at the coil.crank no spark. any help?/ thanks phil I'll check back and forth helping son with school.
hulmule is offline
Old 05-03-2007, 09:07 PM   #2
My Ride: '89 Daytona Shelby
There is a black plastic piece of electronics with (2) plug connectors between the distributor cap and the distributor body. It's called a "Hall Effect Processor" (or, HEP) This part is responsible for telling the computer that the distributor is turning. The computer then allows spark and fuel to flow.
Good chance this part is burned out. If you can get a known good one (must be from a turbo car **(2) connectors ... '86 or newer) and swap it in you may be golden. Then order a new Mopar replacement.
puppet is offline
Old 05-03-2007, 09:15 PM   #3
should i just go buy one? i dont have any spare parts.any way to check that part? has to be a turbo huh.autozone tomorrow i guess.i read up on that tonight thanks phil.
hulmule is offline
Old 05-03-2007, 10:52 PM   #4
Any junk yards in Ohio?
puppet is offline
Old 05-04-2007, 02:30 AM   #5
Kind of jumping the gun on the HEP. First, when you turn the key on, you should hear the fuel pump prime for a second. If you can't hear it, put a test light on the pos. side of the coil and the neg side of the battery. when you turn the key on, the test light should light up for a second. If you hear the pump prime, or you see the test light illuminate for a second, then you can look at the HEP.
If you do NOT see the test light light up, or you do NOT hear the fuel pump prime, then it is probably the ASD relay.
anonymous_user is offline
Debt Consolidation | Proxy | Problem Mortgage | Free Advertising | Loans
Page generated in 0.30679 seconds with 13 queries
