Old 05-05-2007, 11:50 AM   #1
Question fwd stage 5 info ??
My Ride: Shelby z 88
Engine: 2.5t2
Images: 7
hello
am buy the stage 5 use am looking for the technical instruction ?
am use the selénoide and have juste 13-15psi ???
the ecu just use whit the g-valve ???
tk's
sorry my english is not very good
SpiritShelby is offline
Old 05-05-2007, 02:00 PM   #2
NO Democracy!
Originally Posted by SpiritShelby
hello
tk's
Yes, your english is not very good, but I think I know what you are saying.
The stage 5 cal is a FWD Performance cal. If you bought this new from them, then you should call them and ask them questions as #1) they have the answers for you #2) they probably speak a little french now that Stephane is part of their team
But, what I think you are asking is boost control. You are best to use a G-valve so you can run whatever boost level you want. Disconnect the vacuum lines at the wastegate solenoid and hook up the g-valve from a dedicated source..no tees and keep the line as short as possible. Also, you should use an adjustable fuel pressure regulator as these cals are setup on the rich/safe side and everyone's car is different.
DirectConnection is offline
Old 05-05-2007, 04:05 PM   #3
Engine: 2.5t2
Images: 7
hey tk's (merci)for the information
fwd stage 5 is use am buy from SL#554
Old 05-05-2007, 05:25 PM   #4
NO Democracy!
Ah...ok. I am sure if you called FWD they would still help you with any other questions you may have as it is their product and like any vendor.... they don't want someone having issues with their product.
Credit Cards | Bankruptcy | Remortgages | Free Ringtone | Buy Anything On eBay
Page generated in 0.32404 seconds with 13 queries
