Old 05-16-2007, 01:48 PM   #1
Knock Sensor Not Working??
My Ride: 90 Shadow VNT comp
Had my car on the dyno saturday,and with a scanner. The scanner showed no info from the knock sensor and it was pinging badly at 13psi and 9 degrees of intial timing.
Whats up? Should there be voltage to the sensor 100% of time? Any suggestions on what i can do to fix this??
bill
bill baker is offline
Old 05-16-2007, 02:17 PM   #2
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
some calibrations especially MP or custom cal's may not use the knock sensor signal; therefore may not send it to the serial scanner port
sposedly you can test your knock sensor by hooking a sensitive voltmeter directly to it and tapping/hitting theintake mani with a hammer (simulating knock) you should see a little jump in the voltage altho maybe not depending on how fast yor meter is ; i spose an oscilliscope would be best but you coult try a VOM first
detobias is offline
Old 05-16-2007, 10:33 PM   #3
My Ride: '89 Daytona Shelby
bill
Just out of curiosity, what were you using for fuel?
puppet is offline
Old 05-16-2007, 11:01 PM   #4
RECORD HOLDER 11second mini
gasketmaster's Avatar
1/4: 11.760
What type of scanner and what type of electronics?
gasketmaster is offline
Old 05-17-2007, 10:04 AM   #5
93 octane with a DRB 2. The cal. is an 88' gary RR. chip
Old 05-17-2007, 12:33 PM   #6
1/4: 11.760
Hey Bill,
I'm also running one of Gary's 88 cals. The instructions came with the correct codes to enter into the scanner so it would sync up to the cal correctly.
I use an OTC 4000E and I'm able to monitor knock retard in all four cylinders with this his cal
I was able to test my sensor by banging on the intake beside the sensor with a 1/2" extension and a hammer while the engine was idling. It would show knock activity on the scanner.......it took a fairly heavy blow to register anything though
Old 05-18-2007, 10:31 AM   #7
well, i guess i have no way of knowing the code.. haha.
Old 05-18-2007, 10:32 AM   #8
Is there a way to see if i have power to the knock sensor? Is there power to it %100 of time??
Old 05-18-2007, 09:57 PM   #9
My Ride: Omni
Engine: 2.2 liter 16V hybrid
There no power to the knock sensor. When knock is present, a AC voltage is create on the tip on the sensor. Oscilloscope is the best tool to see if it work .
guidsm is offline
Homeowner Loans | Debt Consolidation | Home Loan | Credit Report | Guitar Lessons
Page generated in 0.84606 seconds with 13 queries
