Old 05-17-2007, 12:27 AM   #1
running lean after istalling MAP bleed???
My Ride: '90 SPIRIT T2
Engine: 2.5 TII
i just installed a g-valve MAP bleed. followed the directions right from gus's site. but now i seem to be running very lean in WOT. could this be related?
thanks
kyle
k-briggs is offline
Old 05-17-2007, 12:43 AM   #2
well when you fool the map sensor by making it think it is seeing less boost than what is really there, what do you expect?
xrattiracer is offline
Old 05-17-2007, 12:59 AM   #3
Engine: 2.5 TII
but tis leaning out at all boost levels. it never went higher than 15psi. its got enough fuel for that.
k-briggs is offline
Old 05-17-2007, 02:10 AM   #4
RECORD HOLDER 11second mini
gasketmaster's Avatar
1/4: 11.760
Are you seeing the proper map voltage at WOT?
gasketmaster is offline
Old 05-17-2007, 05:57 AM   #5
A MAP bleed will lean out the whole curve. You are bleeding off some of the manifold pressure before it gets to the MAP, so if you are at 5 psi manifold pressure, you might only see 3-4 psi at the MAP. You will need to raise your fuel pressure to compensate.
Now, if you are using a pressure relief valve on the MAP signal - aka a grainger valve type MAP clamp - then it should only lean out when the valve opens. You will need to control fuel above the setting, but below it should be fine.
When you say a MAP bleed, do you really mean a bleed or a g-valve type?
anonymous_user is offline
Old 05-17-2007, 07:13 AM   #6
Engine: 2.5 TII
this is what i have.
k-briggs is offline
Old 05-17-2007, 12:39 PM   #7
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
what happens if you tighten it?
RPMurph is offline
Old 05-17-2007, 03:12 PM   #8
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
the ball/check G-valves dont necessarily seal 100% when they are closed so you may have a slight 'bleed' at pressures less than you expect
a slight leakage may not be significant when operating on a wastegate circuit, but perhaps significant on a MAP vacuum circuit
I'm running a 4.3v zener diode myself - essentially functions the same way as your Gvalve but does it electrically instead of pneumatically; also simpler install, cleaner (hidden), less chance for errors & problems (e.g. dirty & sticking or leaking Gvalve)
detobias is offline
Mortgage | Internet Advertising | Web Advertising | Problem Mortgage | Loans
Page generated in 0.35706 seconds with 13 queries
