Old 07-01-2007, 09:19 AM   #1
AFPR - install?
My Ride: 92 sundance duster
Engine: 3.0L 24v
ok, im being dumb ...i got an ebay AFPR (which came w/o instructions) and im not sure how to hook it up etc. i know the small port is MAP source, but i dont know which of the two large ports is fuel in or fuel out. also is the set screw looser = more pressure or is it reversed?
Shadow24V is offline
Old 07-01-2007, 09:43 AM   #2
My Ride: '89 Daytona Shelby
My guess by looking at it is that the nipple above the flange is vacuum source ... the nipple pointing down is fuel "IN" ... the nipple pointing right is "OUT/RETURN".
puppet is offline
Old 07-01-2007, 11:18 AM   #3
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
I would remove the pressure gauge, and blow through the nipples. whichever you blow and makes the air come out the gauge port is the in. Reason being, the gauge would have to see the same pressure the "in" port in order to function.
dyno sheet
fmic install:
crazymadbastard is offline
Old 07-01-2007, 12:59 PM   #4
Engine: 3.0L 24v
good ideas, puppet's makes sense looking at the stock FPR so we shall see. ill get it running first as i dont NEED the AFPR right away.
Old 08-30-2007, 06:32 AM   #5
My Ride: 91 Shadow turbo vert
did u ever get this installed?
amiturbo is offline
Old 08-30-2007, 04:05 PM   #6
Engine: 3.0L 24v
not yet, project is on hold due to college for the time being, 400 miles away from the car :'(
Free Ringtones | Mortgages | Project cars | Gaia Online Cheats | Buy PSP
Page generated in 0.35977 seconds with 13 queries
