Old 07-23-2007, 12:43 PM   #1
Replaced fuel Filter
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
This may sound like a corny question, but i gotta rule out my issue. Does it matter which was the lines are hooked up on a fuel filter on a daytona, lebaron etc?
xtrempickup is offline
Old 07-23-2007, 12:59 PM   #2
Most of the filters I have are labeled in and out. I *think* the inlet is usually in the centre.
william is offline
Old 07-23-2007, 03:28 PM   #3
My Ride: TIII R/T
Feedback: (10)
mine has out labeled in both spots, thats why i wans wondering, getting a fuel starvation problem, not sure if its a weak pump or something else
Old 07-23-2007, 03:39 PM   #4
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
That is a good q, I will look at the fsm. I put them in the same way they come out.
dyno sheet
fmic install:
crazymadbastard is offline
Old 07-23-2007, 05:00 PM   #5
Turbo224's Avatar
My Ride: Daytona R/t
Engine: Turbo III
Images: 224
Just did the filter in my omni on saturday, and the out port is in the center.
~Tyler~Salt Lake City~Proud SDAC Memeber~
-92 Daytona R/T (PVP Pilot Car)
-92 Daytona R/T
-87 GLHS #907
-86 Omni GLH-T
-70 Plymouth Cuda 440-6pk (in progress...sort of)
Check out my Homepage
"Half the people you know are below average"
Turbo224 is offline
Old 07-23-2007, 06:51 PM   #6
My Ride: TIII R/T
Feedback: (10)
i think its hooked up right, doubt its my prob
Xbox Mod Chip | Guitar Lessons | Bad Credit Mortgages | Xecuter 3 Mod Chip | Car Loan
Page generated in 0.36863 seconds with 13 queries
