Old 07-25-2007, 06:35 PM   #1
Turbo ii Fuel Rail Removal
My Ride: Various
I have a leak at one of my fuel injectors on my '87 Daytona Shelby Turbo ii. I tried to remove the fuel rail, but could not get enough clearance at the injector under the regulator. Is there a trick to getting this off without removing the upper intake plenum?
Any advice would be appreciated.
Rob.
66CudaFormulaS is offline
Old 07-25-2007, 06:57 PM   #2
My Ride: 85 glh turbo
Engine: 2.2 turbo
1/4: 11.510
I removed the diaphram(sp) "thingy" at the end of the fuel rail and also removed the fuel pressure regulator. That will give you enough clearance to remove the fuel rail with the injectors still attached. It is a little tricky but possible. Now thinking back, I think that I removed the valve cover also, not sure on that but you will know it if you need more clearance. Good luck
85glht is offline
Old 07-25-2007, 07:15 PM   #3
My Ride: 85 GLHT, 87 ShelbyZ
yep remove the valve cover too, you should be able to leave the diaphram and the throttle body end on.
GLHNSLHT2 is offline
Advertising | Mortgages | Debt Consolidation | Librerias | Free Web Development Code
Page generated in 0.27994 seconds with 13 queries
