Old 08-09-2007, 12:53 PM   #1
Found Replacement LM Terminals
My Ride: 86 GLH Turbo
Engine: 2.2L T2
I found a local supplier that has 300 terminals exact to the ones found on our LM mating connector. If your like me and have to keep cutting off connectors from junkyard cars to fix your shorts in your harness then i'm sure your fed up with doing that. I'm planning on getting some soon so i figured since most companys have stopped stocking these that i could share this find. Let me know if you would like me to get some for you and i might even buy the whole lot.
kevin
GLH_Turbo22 is offline
Old 09-27-2007, 12:22 AM   #2
logic mod
hi you have saved the day i have a 85 glh omni and i unpluged the logic mod and a few of the pins in the main harnest broke from being wet and roted if the pins are the same i will take a bunch let me know what you needto ship them
thanks mark
markisglh is offline
Old 09-27-2007, 08:06 AM   #3
Engine: 2.2L T2
Well I posted this a while back and nobody responded to it, so I only bought as many as I needed. I can see if I can find the contact info and send it to you.
Kevin
Old 09-27-2007, 10:37 AM   #4
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
Terminal supply co. 7 location across the country. One is near Detroit, One is 2 miles from me in St. Louis. Probably best to call then ship one old one to them. They have a downloadable pdf catalog also.
looneytuner is offline
Old 09-27-2007, 10:49 AM   #5
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
I remember reading that old AT power supplies have the same pins.
dyno sheet
fmic install:
crazymadbastard is offline
Old 09-27-2007, 10:32 PM   #6
whats a AT power supplies
Old 09-27-2007, 10:34 PM   #7
My Ride: 1986 GLHS #065
Engine: 535hpAluminumLongRod
1/4: 11.921
Images: 19
wanna know a secret? Go buy a dodge radio harness adapter and then you will have about 20
SUPER60omni is offline
Old 09-27-2007, 10:45 PM   #8
thanks all of you have been a real big help
Old 09-27-2007, 10:47 PM   #9
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
old computer power supply connector.
dyno sheet
fmic install:
Mortgages | Guitar Lessons | Cell Phones | Online Advertising | Bad Credit Mortgages
Page generated in 0.48614 seconds with 13 queries
