Old 09-04-2007, 06:20 PM   #1
Injectors...
My Ride: 87 SHELBY DAYTONA Z
Engine: 2.2 T2
Hey guys im running an 87 shelby daytona z
done alot of up grades, 255 fuel pump, FMIC, water meth injection, stage 2 logic mod, anyway last year when i hade this stuff on there my A/F guage was reading pretty lean until WOT, had some other problems and didnt get to finish it until now, but i was thinking about putting on some +40's to maybe help that out? what do you think... im running close to 18-20 psi... any and all help would be nice..thanks guys.
lancerman23 is offline
Old 09-04-2007, 07:13 PM   #2
My Ride: 85 GLHT, 87 ShelbyZ
you'll need to either run an AFPR and a RRG AFRR or have a custom ECU made to run them at the stock pressure.
GLHNSLHT2 is offline
Old 09-05-2007, 12:47 PM   #3
injectors...
Engine: 2.2 T2
why is that?.... and where can i get a ecu for it? im running the stage 2 from forward motion..? or does that matter....
Old 09-07-2007, 02:18 PM   #4
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
You're running 18-20 psi on stock injectors and on stock fuel pressure?
cawcislo is offline
Old 09-07-2007, 07:19 PM   #5
because if you don't do it that way you'll have +40% more fuel almost everywhere and it'll flood the motor out or just make it way down on power. You really need a wideband a/f gauge setup to see just how lean you're running. The Stage 2 cal is worse for high boost than a stock puter. Why? Because the stage 2 leans the WOT fuel curve out vs. stock.
Old 09-07-2007, 07:52 PM   #6
TurboDodge.com Admin
moparfwdsleeper's Avatar
Feedback: (34)
Images: 187
I'd do some research on the MP stage 2 that you are using. Find out where it's sweet spot is for boost. 18-20psi seem's like it would be to much for the MP Stage2 ecu. Do some searching and find what MP requires for the use of a stage 2. If you are dead set on keeping the 18-20psi then contact TU for a custom cal or FWD-P for a Stage 5 and add a wideband to the order! A narrowband A/F gauge isn't going to give you anything really useful for tuning, rather a few pretty bouncing around lights
Clayton
TurboDodge.com Forum Admin
Payments on shirts due by 12:01AM January 16.
moparfwdsleeper is offline
Old 09-09-2007, 02:23 PM   #7
My Ride: 88 CSX-T
Engine: 2.2 Turbo II
Images: 9
There is some interesting information on programing your computer at MoparChEM.com if you are pretty good with computers. One problem you can also run into with high boost on some computers is most MAP sensors are only 1 bar sensors (i.e. 14.7psi) and after that dont know what boost you are running. Thats why when these cars were new we had to add additional injectors for high boost.
thnder7 is offline
Ringtones | Mortgage | MPAA | Free Online Games | Loans
Page generated in 0.42056 seconds with 13 queries
