09-09-2007, 02:17 PM
My Ride: 88 CSX-T
Engine: 2.2 Turbo II
Basically, what the car is doing, aside from turing the check engine light on, is that it will run and perform fine at part throttle operation while it is taking readings from the O2 sensor but when you go full throttle and it stops taking O2 readings its performance is lack luster. The computer uses the temp sensor to determine the charge air density so it can map the required fuel. Without this sensor it doesnt have anyway to know how well the intercooler is working to reduce the charge air temp.
