Old 09-24-2007, 01:44 AM   #1
Re; 210 ft/lbs torque or 170?
My Ride: 91 shadow convert.
Engine: 2.5t
Images: 14
I've read contrary articles regarding the torque output of the 91 shadows 2.5t as to callibration of fuel mix and advance. The difference supposedly is between the standard or auto trans.
COASTAL SHADOW is offline
Old 09-24-2007, 01:47 AM   #2
Engine: 2.5t
Images: 14
Sorry, didn't actually ask a question. Can anyone say for sure if the 210 came in the standard or auto?
Old 09-24-2007, 02:49 AM   #3
Info from 1990 Chrysler Service Manual
2.2L T4 210 Lbs.-Ft. @ 2400 RPM
(The window sticker says 210 @ 3200 RPM)
2.5L T1 180 Lbs.-Ft. @ 2000 RPM
Old 09-24-2007, 03:20 AM   #4
My Ride: 92 Shadow
Engine: 2.5 T1
Window sticker for my 92 auto T-1 says 210 lbft. at 2400 rpm. It all depends on how much boost is running and whether or not its limited at certain rpms.
bhazard is offline
Old 09-24-2007, 03:27 AM   #5
Engine: 2.5t
Images: 14
Just going back through the pioneers works I see that the calibrations were 2.5 and specific to the trans.
Old 09-24-2007, 12:03 PM   #6
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
The 2.5 t1 in 92 got a High torque cal with the 568 tranny, so 210+ sounds right for a stick equipted car.
dyno sheet
fmic install:
crazymadbastard is online now
Old 09-24-2007, 01:33 PM   #7
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
The ONLY difference was the boost schedule. The autos limited boost below ~3k rpm to ~7psi or so. If you put a hi-torq computer into an auto car, you get 210ft-lbs. Hell, if you put a grainger on a AT computer you'd get the same 210ft-lbs. The hi-torq cal is really nothing special at all...
Shel-Game is offline
Old 01-05-2008, 09:04 PM   #8
Re: Re; 210 ft/lbs torque or 170?
My Ride: 1988 dodge shadow es
Engine: 2.5 turbo
that torque difference occured in 91 the sticks got the faster boost schedule and the 210 ft/lbs of torque at 2100rpm
dcshadow is offline
Old 01-05-2008, 11:33 PM   #9
Engine: 2.5t
Images: 14
THAT, I believe, actually answers my question. I was trying to determine if 91 was the first year that this came stock with a t-1, and if it was auto or stick.
Old 01-06-2008, 12:06 AM   #10
My Ride: Chrysler Daytona C/S
Engine: 2.5L
Images: 1
91' was the first year to have high torque on 2.5 T1 and it is only available on manual trans from factory, no auto at all.
venom800tt is offline
Online Dating | Bankruptcy | Loans | Loans | CreditCards
Page generated in 0.40917 seconds with 13 queries
