10-24-2007, 06:26 AM
Re: Erratic Fuel Gage
You will need an OBD2 compatable scan tool and I do not know if aftermarket scanners will access Compass/Mini Trip.
First you have to determine if there are any PCM faults as this may affect the way the Compass/Mini Trip Computer reads.
Is it only the trip computer that reads erratically or the gauge also?
If the gauge is also reading erratically start by replacing the sending unit.Sending unit was a big problem on all Jeep models from that time period,the Dakota is probably the same setup.You can purchase the redisigned sending unit at any dealer.
If it is only the trip computer and there are no PCM or Body codes and the trip computer fails the self test Chrysler says replace the trip computer.
Again you will need a scanner(Chrysler DRB3)to run all appropriate diagnostics.
