10-27-2007, 12:51 PM
Re: New project need some help.
My Ride: 1993 Daytona
Engine: 2.5L MPI N/A
You could run it decently on your stock electronics as long as you get like a wideband O2 sensor or EGT gauge with AFPR to inject the right amount of fuel. That's really all you need. And if you increase airflow later down the line, you just compensate by increasing fuel pressure. The ONLY thing is that the ECUs won't "see" is the increased airflow of the mpi and any possible head porting or exhaust upgrades. Not sure just how much of an impact this has. I'm not sure just how smooth this would idle, I know my MPI car ran super smooth with the fuel pressure down at 35psi, but I had no way to know my A/F ratio and see if I was lean or not, so I put it up to 45psi and it runs ok. I'm going to get an EGT gauge later down the line and hopefully solve this problem once and for all.
But if you want the sequential injection, you'd need either a turbo electronics swap, which wouldn't be ideal, a mexican/ffv mpi swap, which is very hard to find, or a standalong engine management system, which costs a bit and I believe you'd need to tune it on a dyno to get it ideal. I don't have any knowledge on megasquirt or other systems, so I can't tell you.
Yeah, it is a pain in the ass, but semi worth it. Turbo is definately the way to go.  Good luck, hope this helps.
