Old 12-12-2007, 03:24 PM   #1
Hot Turbo smog problem
I am trying to tune a 85' T1 engine for smog tests.
When the engine is fully warm, I experience problems:
1. high idle speed about 1100 rpm+ (eventhough idle control valve is closed)
2. brief rich surges... as if oil is being pulled past turbo seals. Happens every few seconds. I do not see smoke. MAP reading dips then jumps a bit.
3. Increased HC emissions
I have checked all hoses for leaks. Engine has been carefully rebuilt.
The condition exists only when engine vacuum is high and I lean the idle mixture for emissions. The engine runs great otherwise.
I plan to change oil wt. from 5-30W to 10-40W. Also install a 180F thermostat instead of 195F. Try to pass before fully warm.
I need help! Here are my questions:
What is a good idle speed? I cannot find a specification in Haynes manual.
Am I on the right track?
Is there anything else I should check or do?
Will synthetic oil help? I heard a rumor that synthetic oil contributes less to HC reading.
Is it time for new turbo seals/rebuild? I hate to do this now, I'm so close.
KitCarlson is offline
Old 12-12-2007, 03:48 PM   #2
Re: Hot Turbo smog problem
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
I would check the pvc valve or maybe eliminate it if you can get away with it. 85 had egr so maybe that might be something to look at.
I practice what I preach:
crazymadbastard is offline
Old 12-12-2007, 04:19 PM   #3
PCV - A great idea! I think that might be it! If I pinch hose the idle drops, that may also be where the oil drops are comming from.
I found that the turbo PCV valve is different from the N/A. I purchased one last night. I have not had time to test yet.
I might try to relocate the PCV valve with a better way to separate the oil/air from the valve cover. I have a aftermarket aircooled VW separator/can that might help. I wish there was a good place to drain back to the crankcase. Any ideas?
When I activate the erg solenoid not much happens in rpm or idle quality. That suggests a problem there too! There is some sort of check valve and vacuum control gizmo, not sure what they do. A good place for me to check further.
Old 12-12-2007, 08:10 PM   #4
My Ride: '87 Daytona Shelby Z
Engine: 2.2l TII
Images: 3
On mine when I unplugged the vacuum line to the egr inducer my idle would smooth out and it would run a lot better. When I took it apart the egr tube was just clogged with carbon. Also is there excessive oil in the air box?
impuresoul2k3 is offline
Loans | Web Advertising | Internet Advertising | Secured Loans | Online Advertising
Page generated in 1.24932 seconds with 13 queries
