12-14-2007, 02:07 PM
Re: EGT Probe Install
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
You can do it in car, I did mine that way. You will however get metal chips into the exhaust manifold, but it never hut my turbo. I removed the airbox and all turbo hoses. You will be drilling your hole on the #4 cylinder (driver side). It should not be too difficult to drill out once the hoses and airbox are out of the way. Go about an inch and a half away from the head or about the middle of the manifold runner. Then drill away. I used a tap to thread the hole I made for my probe setup, that was a bit tricky, but still not too bad. Good luck.
87 Daytona Shelby Z 2.5 T2-> cummins cooler, 3" exhaust, S60, forged venolias, TU custom 3 bar cal 18 psi... ported +1 head Lookin to go low 13's.. extra lean - need a good tune and now having clutch issues too.
