Old 12-31-2007, 09:46 AM   #16
Re: cant rev over 2000
My Ride: 1987 caravan
Engine: 2.2 carb
or catalyst converter partially plugged up.
Cheers, Wizard
Wizard is offline
Old 12-31-2007, 03:19 PM   #17
My Ride: shelby csx-t
Engine: 2.5 turbo
my pcv valve is cracked and hard and so is another hose behind the cover so ill change those to and see what happens
xsaigen is offline
Old 12-31-2007, 05:41 PM   #18
Engine: 2.5 turbo
i changed all my hoses that looked bad and its still doing the samething and i think my timing is right im going to get a diagnosestic done to it on wedesday to see whats up thats for the help and if anyone else has any suggestions im ready to listen.
xsaigen is offline
Old 01-01-2008, 04:25 PM   #19
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
When this thing falls flat on its face at 2000 RPM, is it smooth, or is it shaking / bucking / jerking?
phantomrt is offline
Old 01-02-2008, 12:55 AM   #20
Engine: 2.5 turbo
its shacking bucking and jerking
xsaigen is offline
Old 01-02-2008, 10:36 AM   #21
Engine: 2.2 carb
You left that vital info out as we can't know if it was smooth revving or bucking, now that
more clear.
Do tune up (ignition timing, check timing belt alignment, plugs and ignition wires, rotor and distributor cap.). If this does not fix this, have fuel pressure monitored while revving up. If pressure falls off, yoiu have problem.
Cheers, Wizard
Wizard is offline
Old 01-02-2008, 12:27 PM   #22
Blue Iroc R/T's Avatar
My Ride: 93 Daytona Iroc R/T
Engine: 2.2l TIII
Re-Set the engine computer to clear the codes. Disconnect the battery for 10 minutes then re-connect it. When you went into the mountains, due to atmospheric changes, the car went into "Limp Mode". IMHO, if you clear the codes that were set, it will then re-learn the new condidtions. It will run like crap for a few minutes and then smooth out. I'd still go ahead and replace that PCV elbow that is hard. Dealer still sells them.
Good Luck.
Ralph
www.pbase.com/rmscott
Blue Iroc R/T is offline
Old 01-02-2008, 04:32 PM   #23
Engine: 2.5 turbo
its wierd it runs good but it idles goes up in down now.
xsaigen is offline
Old 01-02-2008, 04:33 PM   #24
Engine: 2.5 turbo
i changed the elbow and reset the computer
xsaigen is offline
Old 01-02-2008, 07:29 PM   #25
Engine: 2.2l TIII
Check the Vacuum line going to the brake booster (a little black canister on the brake booster). If it is off, the idle will fluctuate.
You probably still have a vacuum leak at one of the connections. Spray carb cleaner around the connections with the engine idling. The engine will pick up rpm when you spay the carb cleaner over a leak area.
Ralph
Old 01-02-2008, 09:04 PM   #26
Engine: 2.5 turbo
ok ill do that and thats to every1 my car runs great except the idle so ill check the brake booster
xsaigen is offline
Old 01-02-2008, 09:14 PM   #27
Engine: 2.5 turbo
thanks to every1 lol i cant spell tonight
xsaigen is offline
Old 01-02-2008, 11:54 PM   #28
Very likely a weak ignition system. How old are the spark plug wires and coil wire? What about cap and rotor? Spray water on them and see if the problem comes back. If it does, thats your problem. The only cheap aftermarket ignition wires I would get are Taylors or a custom set of Accel spiral cores. Otherwise, Mopar wires.
Old 01-03-2008, 12:02 AM   #29
Engine: 2.5 turbo
i just had to re-set my computer and i need to fix my idle it goes up and down
xsaigen is offline
Old 01-03-2008, 08:31 AM   #30
The idle is going up and down because the controller is trying to correct the idle speed.
The easiest way to locate your problem will be to get the AIS out of the system so you do not have the surge.
A vacuum leak at the booster is central to the system and would create a high idle condition.
Be sure that your idle problem is not related to carboned throttle plates and/or AIS pintle.
Follow the instructions in the "sticky", "help with poor idle" in the "help" section.
If the problem persists get the vehicle to base idle with the AIS out of the system and then look for vacuum leaks or other related problems and you will not have to deal with the controller trying to correct the idle speed.
Bankruptcy | Online Dating | Adverse Credit Remortgage | Mmorpg | Buy PSP
Page generated in 0.48330 seconds with 13 queries
