Old 01-25-2008, 08:56 PM   #1
anyone using an MSD Blaster 3 coil?
Hybrid Booster
My Ride: 85 Omni GLH
I got one with Magnacore plug wires from FWDP, but the coil tower is different from factory coil, so the wires won't work with the new coil without cutting them up, which I don't want to do, cuz I want it perfect. The coil to cap wire is obviously the most important. Looks like the Blaster 2 would work fine, and the internals are supposed to be the same. THought maybe I could pull the tall tower off the Blaster 3 coil (maybe it's just an adaptor), but it seems to be permanent. Anyone using this set-up? thanks...
fiater is offline
Old 01-25-2008, 09:22 PM   #2
Re: anyone using an MSD Blaster 3 coil?
My Ride: 84 Plymouth Turismo
Engine: 89 2.5 I/C TURBO
My thoughts are that the MSD is really only good at high RPMs. correct me if am wrong here... The Factory coils are decent enough IMO
Robb The "MO": 84 Plymouth Turismo..::2.5 CB MPI INTERCOOLED TURBO/ Updated Aug 30/07 - London, Ontario
TurboTurismo is offline
Old 01-26-2008, 10:40 AM   #3
My Ride: '89 Daytona Shelby
Problem with these coils is that vibration tends to loosen those terminal rod connections inside the tower insulator. That and I don't think there is as much oil inside the bodies ... unlike the OEM coils ... to cool them. I haven't had the best of luck with these coils.
I'd dump it in favor of a Mallory ... or just stick with OEM.
puppet is offline
Home Loan | Loans | Mobile Phone | Cheap Loan | Loans
Page generated in 0.29230 seconds with 13 queries
