Old 02-01-2008, 01:51 AM   #1
whats the deal with colder spark plugs
My Ride: 90 Daytona ES
Engine: 2.5 Turbo 1
okay whats the trade off with hotter/colder spark plugs? (for our turbo engines)
if colder ones are better on turbos, why didnt chrysler just spec colder ones to begin with?
there is no big cost difference right?
whats the deal.
what are the PROS
what are the CONS
acannell is offline
Old 02-01-2008, 01:56 AM   #2
Re: whats the deal with colder spark plugs
Engine: 2.5 Turbo 1
check this out:
NGK heat range info
SO
lets say I turn the boost up to 15 psi on my 2.5 turbo, and then I add a HUGE intercooler and +40's, etc... so that there is enough fuel.
now if I observe my EGT's after the mods, and they are within the range I like (whatever that range might be), then I wouldnt want a colder plug right?
acannell is offline
Old 02-01-2008, 07:29 PM   #3
My Ride: 86 SC & 98 Neon
1/4: 9.900
colder plug just means that it will disspate heat in the tip faster.
So if you're running lots of boost, the combustion chamber gets hot. If the plugs tip gets too hot, it can cause detonation, so colder is safer for high (higher than stock) boost.
Under normal driving, cold plug will foul, so thats why it's not a factory item. Some foreign cars run hotter (for better gas mileage) and they use colder plugs to make up for it.
I don't consider 15psi high, many TDers run 25-30psi, so cold plug is important. Fouling on the way to and from races is the norm.
DblTrbl is offline
Credit Cards | Per Insurance | Personal Loans | Free Ringtone | Personal Finance
Page generated in 0.30365 seconds with 13 queries
