03-30-2003, 12:26 AM
My Ride: DOdge Shadow ES
Engine: 2.5l
You will have to find where the previous owner hooked into the locks. There will be two different colored wires which have been cut and you just need to hook them back together again. They will most likely be behind eihter the driver's or passengers kick panel. if not there thatn possibley behind the glove box somewhere. I don't think I have ever done locks in a Daytona specifically but this is where they are for almost all vehichles. They should be a larger gauge wire (about 12ga.) Unless the alarm had been installed proffesionally, there should be some big butt conectors used so they should be easy to spot. It is OK to re attatch them with butt conectors as long as you use some good crimpers. Otherwise use solder and they will never come apart. I will be at work tommorow so I will try to get some wire colors for you as well, but hopefully this will help for now.
