02-22-2008, 06:11 PM
Re: Code 52
The possibilities for code 52 (rich exhaust indication) are,
Cam Timing, Ignition Timing, Engine Sealing/Vacuum Leak,Misrouted Vacuum Lines (causing low vacuum to baro/map) High Fuel Pressure,Leaking Fuel Pressure Regulator,Leaking Fuel Injector(s),Map/Coolant/Air Charge(if equipped) Sensors out of range, faulty O2 Sensor, Faulty Controller.
Map and FPR recieve vacuum from a manifold vacuum source,vacuum must be 16-20 "HG at idle.
Chrysler had problems with the LM mounted Map sensor vacuum line with moisture freezing in the line.
