Old 03-02-2008, 04:52 PM   #1
.020 oversized. should i go w/colder plug?
My Ride: 86 GLHT
curently running a stock T1 setup with my pistons .020 oversized, and a 2.5 exhaust turbo back. i am using champion plugs stock heat range. they are not running totally white but not the normal lightbrown either should i go with a colder plug?? should i change my timing also right now it is a 10 degr.
Thanks
Troy
GLHTroy is offline
Old 03-03-2008, 10:05 PM   #2
Re: .020 oversized. should i go w/colder plug?
My Ride: 1986 GLHS #065
Engine: 2.2 Aluminum LongRod
1/4: 11.921
Images: 19
a stock T1 setup is fine with RN12YC's. 10deg. of timing is nice and conservative and will help your pistons live. Just make sure you use premium!
SUPER60omni is offline
Old 03-04-2008, 08:13 AM   #3
If you aren't running over stock boost than just run stock plugs. And there's nothing wrong with 12 degree timing, you could run 14 degree's if you wanted for better fuel economy.
I've run 17 PSI non-intercooled with a stock 2.5L, and 24 PSI intercooled on pump 93 octane with 12 degree timing. No broken pistons. Anyone that tells you to run less than stock timing with the stock amount of boost is just paranoid. All you are doing is hurting your fuel economy.
87dtna is offline
Old 03-04-2008, 12:03 PM   #4
My Ride: 86 GLHT
thanks for the advice i am jus worried due to the way my plugs look never had a turbo car before so i am learnin as i go
thanks again
Troy
GLHTroy is offline
Old 03-04-2008, 02:23 PM   #5
Like brown is pretty good, a hair rich but on the safer side air/fuel mixture.
Have you looked at the dodge garage yet?
Donovan's Dodge Garage
Check out the turbo database on the left hand column, great reading for hours and you'll learn tons. Not everything is 100% accurate, but it's 95% and great for starters.
87dtna is offline
Online Loans | Remortgages | Hotel Las Vegas | Consolidate Debt | Loans
Page generated in 0.51790 seconds with 13 queries
