03-14-2008, 08:36 AM
#31
Re: 87 tona, wont rev past 4500, now is dead.
My Ride: '88 Daytona w/t-tops
Engine: 1.65 TII-3 Cyl-lol
My money is on a bad injector/dead cylinder. What you should have done is cool down all of the way, start it, and reach back and feel the exhaust manifold. Put your hand on the runner for each cylinder and you should feel them getting warm within a few seconds. If one doesn't then that's your missing cylinder.
Dumb question, but you did check for spark across ALL four.
03-14-2008, 02:05 PM
#32
My Ride: 87 shelby z daytona
Engine: 2.257L t2
Yes i have spark on all 4. but #4 fuel injector wasnt spraying at all. that plug was clean and from the vid it does sound oddly like a 3 banger lol.. i pull the plug wire and it makes no diffrence on how it runs.
03-14-2008, 03:36 PM
#33
Garrett Booster
My Ride: 88 shelby z
Engine: 2.5l 8v
when i bought my 89 daytona shelby the knock sensor was cracked and dangling. it was acting the same way. i replaced it and it was alot better. i think it was running retarded all the time  . but let is know what the shop finds.....
travis
03-14-2008, 03:38 PM
#34
Engine: 2.257L t2
travis
Will do man. there posed to call me today, i drove past there aw the door open on my car still in the shop bay... so they had to of done something to it lol... just waiting on the call. hopefuly they can get it fixed before my tags expire cuz i still have to put a cat in it to pass e-check. :P
03-14-2008, 06:05 PM
#35
Engine: 2.257L t2
ok the temp sensor was reading -67* and the map was just saying f u.. he also thinks there mite be some misc wireing problem, so hes putting on a 3 bar map, and a new temp sensor, and if thats all it needs then ill have the car on the road tomorrow for 140 bucks  CHEAP! i like this place. ill update tomorrow. now i just need to find 140 bucks laying around lol.
03-14-2008, 10:18 PM
#36
My Ride: 91 CS 2.5T Daytona
No such thing as a dumb question... I'll take any and all ideas at this point... Mine has no misfire at all at idle so they all fire and get hot until I rev it.
I'll start pulling plug wires when it is rev'd to see if it's consistently one cylinder.
maybe I can close in on the culprit. Anything is worth a try.
TDoc: I'll really be curious what else they might find... I have had a temp sensor code before, although not currently throwing code now. I just figured it was because I had it unplugged checking the timing???
I'll go down and buy a new sensor and give it a try. Using my laser temp pointer thingy, I've got ~190 degrees at the thermostat housing, so I know its getting warm & T-stat not stuck open.
03-14-2008, 10:20 PM
#37
travis
Travis,
that is something I haven't thought about... Where the heck is the knock sensor located???
03-14-2008, 11:06 PM
#39
Garrett Booster
Engine: 2.5l 8v
its right between the 2nd and 3rd injectors on the intake manifold. It didn't even set faults either
Travis
03-15-2008, 09:39 AM
#41
Garrett Booster
Engine: 2.5l 8v
thats what mine is starting to do now. im gonna get an hep. thats the only thing i havent gotten yet
03-15-2008, 10:28 AM
#42
My Ride: 87 Shelby Z Daytona
Engine: 2.2 T2
i also got a question mine runs great in the morning, no missfiring boosts great all through the powerband, but after it gets warm after driving it for a while, it starts to do the same thing starts missfiring at 3,700rpm and wont rev past 4,500, also wont boost the same morning 16-18 after a while 13-15 and unsteady, little backround 87 daytona TII FM E2 turbo, computer and fuel mods to work with it. i should be able to do a couple more things and run 25psi like i want to. but i gotta figure out the problem first. oh yeah, it was doing this before and after replacing the hep
03-15-2008, 05:10 PM
#43
Well, I have had my head completely up my A$$.
Using a timing light to check cam timing is NOT accurate! There is way too much tolerance between the hole in the cover and the mark on the pulley. I was a tooth off (And have been for a long long time apparently unless it slipped a tooth somehow). I pulled the thing all apart, got out my straight edge and lined up all the marks... Bottom end was good, but the top was off.
She'll rev to the moon now. Only thing left I have to figure out is why my tach is intermittently not working. I can turn my boost back up and go for a ride
Thanks to all who have chimed in and at least got me headed in the right direction. TDoc, what did that shop figure out on yours???
03-15-2008, 05:14 PM
#44
I'd bet $$ on your cam timing too... I went thru the entire process as if I was putting a new belt on it (Mine was pretty new anyhow so I didn't change it)
Took it all apart so I could see the marks... The top one is deceiving unless you have the valve cover off.
Mine's running great now! Keep us posted?
03-15-2008, 07:20 PM
#45
My Ride: 89 Daytona Shelby
Engine: 2.5L 16V
Ah yes the 4500 rpm spark scatter... I fought this same problem for 2 months. The car sat over winter and when I brought it out I coulda swore some one stuck a two step on it and was ****ing with me. After much agony wasted money and wiring harness teardown I went to drain my oil for a trip to carlsile and found a interesting gold metal flake color to it. I pulled my pan and got to looking around and found that the oil pump drive gear was damn near worn off. this gear also drives your dist. play here causes massive spark scatter. i put a new mopar pump and intermediate shaft in it. problem solved.
