05-17-2008, 03:47 AM
#31
Re: Lazy o2 sensor?
My Ride: Saratoga -93
Engine: 3.0 V6
Ok, i did the "Controller Grounds", "Fuel Pressure" -tests and completed with no problem. Secondary ignition was tested with an INLINE light, since that was only type i could find here, light lit up the same with every plug. I also adjusted timining. The same time we tested the compression also, just in case. I didn't expect there to be nothing wrong with them, because of recent rebuild. Very even pressures, 8.7 psi difference between highest and lowest reading.
What should i be testing next..?
