Old 04-05-2008, 05:54 PM   #1
new cal. boost controller?
My Ride: 88 shadow
i just got a new cal fom FWD. Cindy said it may take anywhere up to 200 miles for it to really get used to the settings and stuff. well its only boosting to about 4 or 5 psi and doesnt seem to want to go any higher. my question is, would it be bad to put the boost controller on it and set it for 14-15psi? if i did that, wouldnt it just get used to it running that and adjust itself accordingly instead of trying to find where its boost is supposed to be?
as far as wiring goes, besides the air charge temp sensor, what else is needed to go from T1 to T2 status?
do i need a 3 bar for 15 psi?
88shadowpjct is offline
Old 04-05-2008, 06:46 PM   #2
Re: new cal. boost controller?
Engine: 2.2L Turbo I
Sounds like your wastegate may be hooked directly to the manifold. Check to see if the actuator is working correctly and is not stuck open. While you could put a manual boost controller on your car, if everything is working correctly the cal should control the boost correctly.
-Dan-
22turbo is offline
Old 04-05-2008, 07:12 PM   #3
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
Many people with cals still use a MBC to control boost(line from intake to actuator with MBC in between).
You need to have the vac lines going to the solenoid to use the cals boost control.
speeduphoria is offline
Old 04-05-2008, 11:42 PM   #4
My Ride: 88 shadow
i double checked the lines. everything is hooked up right. it was boosting about 7-9 with the old computer. now with the cal in, it wont get past 5.
Old 04-06-2008, 10:46 AM   #5
My Ride: 88 daytona pacifica
Engine: 2.2, t3/t4 fmic
I would just run a new vac line for the wastegate and use a boost controller.
and by pass the stock boost selenoid
88jbody is offline
Old 04-06-2008, 12:39 PM   #6
My Ride: 88 shadow
so should i let the comp reset and hook up the MBC then let the computer learn again and this time, it'll be like telling the computer.. "listen.. this is how much boost you're gonna run. figure it out." ??
Loans | Credit Cards | Loans | Internet Advertising | Best Credit Cards
1320drag - Drag Racing resource Nissan 240 Forum Audi Forum My Chemical Romance Forum BonneVille Forum Chevrole Forum Camaro Forum Car Audio Forum Car Video Forum Canadian Mutsang Forum Dodge Intrepid Forum Emma Watson Fan Site GM Forum Tuner news GT cars Honda Forum Jeep Forum Mazda Miata Forum RC Forum Mustang Forum Dodge Forum Zero Hurtz
Page generated in 0.29155 seconds with 13 queries
