04-03-2003, 12:04 AM
Lego mindstorms/Robolab datalogger?
My Ride: 85 shelby charger
Engine: 2.2 liter I-4
I'm not sure if anyone here is familar with what I'm talking about, but I bought one of the Robolab kits for an engineering class and since then have thought alot about using it for a datalogger/"event activation" device. The "brain" on these units has 3 inputs and 3 outputs, it can record activities (voltage, temp, pressure, pretty much any gauge) with intervals as small as 1/1000 of a second, possibly smaller need to look into it. You can download the recorded info to a computer using a infrared tower on your computer, it will download onto the computer in very easy to read graphs the can easily be compared and manipulated. The brain can also be programmed to trigger the outputs when a certain input event is met. The programming is extremely easy(similar to C++ but using all icons), best of all you can get the brain for under $100, I figured it can be used to monitor the O2 and kick on extra injectors or an intercooler sprayer etc. Could also monitor boost pressure, intake temp, IC inlet vs outlet temp, all kinds of things. So what do you guys think? Think people would really look at me weird when I had a lego brain hooked up to the car?
