Old 04-08-2008, 06:36 PM   #1
Need help asap! N/A gas tank vs turbo gas tank
Turbo-Baron's Avatar
My Ride: 89 lebaron /shadow
Engine: 2.5 turbo
Images: 20
So i probably should have posted this before i bought the tank and ripped out my old one but here it goes. Im doing the tank on my 89TI shadow.I was told by a few people that the only differnce is the fuel pump.Well i have my old tank and new one sittin in my driveway. I pulled the sending unit out of the new tank and it just popped out.I just went to pull it out of my old tank and it's completly differnt.On the turbo tank there is a hose going from the sending unit to a channel underneath the fuel pump in the tank. Wtf? Do i need a turbo tank? PLease help asap as i said everything is in my drivway and i need my car so i can work.
Thanks in advance
Brendan
Turbo-Baron is offline
Old 04-08-2008, 06:40 PM   #2
Re: Need help asap! N/A gas tank vs turbo gas tank
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
Shouldn't be posting since I don't know about 88-89 Le Barons ,but my 1st gen Daytonas use a specific tank.Turbos have sender and pump together--N/A have seperate holes for sender and pump.
4Daytonas is offline
Old 04-08-2008, 06:51 PM   #3
My Ride: 1989 Daytona Shelby
Feedback: (6)
If you can't figure it out I got a new one from Quanta Products I was very pleased and it even had the turbo baffel, decent price also.
ShelbyMopar89 is offline
Old 04-10-2008, 02:20 AM   #4
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
i had to swap out the tank on my 88 TI lebaron- was the same as the N/A tank. at least for a v6 N/A tank anyway only differences i found were the newer tanks from i believe 91 up have a different fuel pump assembly- the hanger and fuel lines are different- the old style uses clamp on fuel lines while the later style uses a quick release type coupling other than that all the tanks appear to be the same, i believe that the tanks for a shadow are the same for a lebarron, im pretty sure they had the same part # from most of the part stores when i was pricng a new one. also a TI fuel pump is the same as a V6 pump. you can get just the stock fuel pump itself without a hanger assembly from advance auto parts- 77 bucks lifetime warranty for a bosch pump that doesnt need a pulsator to go with.
crusty shadow is offline
Free Ringtones | Adverse Credit Remortgage | Loans | Best Credit Cards | Mortgages
Page generated in 0.30474 seconds with 13 queries
