there are a few things to discuss. Is your intercooler big enough and doing the job of cooling the air? If not don't turn up the boost in the first place, nothing over 20 with a stock type IC should be a rule.
Then comes who is doing what with a MBC. This means are you running a boost cut out riser on a stock computer? A stock computer pulls less timing than a performance cal because many hit cut out early. Then a 2 bar cal running 25 PSI? Thats 10 PSI of boost PAST the timing curve. Many have done this for years.
So "if" you have the right FMIC and 3 bar cal the engine should run 25 PSI at 12:1 AF no problem. Running a stock IC with a tiny turbo and a 2 bar cal? You can but I won't ever say it is ok and feel free to drown the engine
The SRT 4 in question is the one from the 12 SRT threads I've done.
Clays black car. Tire dynos and holds 13:1 AF. It has a BFMIC, not a stocker. A stage 1 MP computer that controls boost. Stock exhaust, not a typo. K&N Typhoon CIA. AGP wastegate can, no other power mods. 12.71 @ 111 MPH on drag radials.
The problem is that he added the AGP wastegate. Clowns that build the SRTs think they need them, they do because the ICs are super restrictive. The stock WG can't hold the boost because of massive exhaust back pressure. Cure the problem and a new one comes up, way too much boost. My brothers car would hold 17 PSI to redline stock and did for 60,000 miles. Why? BFMIC, same spearco on clays car. This IC also really helps the lack of fuel. wideband info is from the dyno guys machine, to give the AF during the RPM range. It has been this way for 3 years or more, time flys I'm going to be 40 in a couple years
