04-06-2003, 01:30 AM
fuel pump
Authorized TD Vendor
Mopar Kid said:
"but FWD Performance says that all is that is needed to install the pumps are a few brass fittings."
OK, I'm not sure where that came from. You may need some brass fittings to install a Fuel Pressure regulator, but not a fuel pump. The fuel pumps we sell come with an install kit. You can put them in a later model car but it will take either some creative fabrication to the old fuel pump holder assembly, which may turn out to be time consuming, or a simplier solution seems to me using a hanger assembly from an 89 turbo car, and mounting your walbro to that hanger and dumping the 90-up modular hanger set-up.
Later,
Cindy
