Old 04-06-2003, 02:28 PM   #1
short some wear
87 glhs most of the time I leave the battery hooked up it drains its.come back in 24hrs to start it and battery is dead. then there is other days i can go three days before its dead.when I hook up the battery cable I get a little spark. Does anyone have any ideals that can help me. Thanks
douglas0413 is offline
Old 04-06-2003, 03:50 PM   #2
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Is it blowing fusible links or fuses consistently?
Try eliminating fuses one at a time to rule out those circuits.
iTurbo is offline
Old 04-06-2003, 04:00 PM   #3
NO IT DOESNT BLOW ANY FUSES AT ALL.
Old 04-06-2003, 04:13 PM   #4
Disconnect the + battery cable, and then disconnect the big white tube connector that supplies power to all the fuselinks/alternator. Then reconnect the + terminal. If the battery still drains with that white connector disconnected, then the short probably has to do with the starter. If the problem disappears, at least you have it narrowed down a little.
iTurbo is offline
Old 04-09-2003, 11:26 AM   #5
DISCONNECTED THE WHITE CONNECTOR AND BATTERY STILL GOES DEAD. SO I HOPE ITS THE STARTER.
Car Blueprints | Remortgages | Magazine Subscription | Mortgages | Remortgages
Page generated in 0.26229 seconds with 13 queries
