Old 04-28-2008, 09:37 PM   #1
Crazy pulsewidth
My Ride: '89 Chrysler Daytona
Engine: 2.5L 4 Rocker!
So, my car seemed to be running a little funky. By this i mean when i would start the car, it would chug and fart and almost stall. I have to keep some throttle on for about 7-10 seconds then it evens out. So for the hell of it, i tossed a noid light on one of the injectors. When i would hand operate the throttle, the noid light would go MENTAL! Like retarded amount of injector pulsing. What would casue this?
Thanks,
Chris
abiba_69 is offline
Old 04-29-2008, 05:59 PM   #2
Re: Crazy pulsewidth
Injector pulse width will increse with TPS movement, lower Map vacuum, lower coolant temp, lower air intake temp or you may have a problem with the control side of the injectors.
Any fault codes set?
Credit Card Consolidation | Problem Mortgage | Xbox Mod Chip | Mortgage Calculator | Loans
Page generated in 0.23107 seconds with 13 queries
