04-08-2003, 08:20 AM
Well, the distributor, injectors and fuel pump all all on the same circuit (fed by the ASD relay). So if you have 12V at the coil but not the pump, I'd check the wires to the pump.
Could also be a bad ASD relay, I suppose. In 84 it was external to the power module, so you'll find it somewhere under the hood (not sure where on '84 models). On '88+ models it's a black plastic bodied relay on the drivers side strut tower.
