Old 05-07-2008, 11:02 AM   #1
Zeitronix wideband: Connect to 3-bar map?
My Ride: Neons + Caravan
Engine: 2.5T
Just seeing if anybody has done it and how they did it if it worked Just trying not to spend another $100+ on yet another sensor
NoDestiny is offline
Old 05-07-2008, 11:28 AM   #2
Re: Zeitronix wideband: Connect to 3-bar map?
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
you can connect the user input to the middle wire on the map sensor. The issues is it will only display voltage AFAIK from down loading the software and poking around a little. So you will need to figure what voltage= boost/vac and/or use a cheat sheet when looking at the data or log so its a pita IMO.
last I knew the sensor could be had on ebay for ~$70
speeduphoria is offline
Credit Cards | Consolidation Debt | Secured Loans | Satellite TV Forum | Ringtones
Page generated in 0.21114 seconds with 12 queries
