05-09-2008, 11:18 PM
Re: 86 T1 and moates gear + t1-t2 turbo swap
I've heard of others using ostrich. Never used it myself though, just have a couple dozen 27sf512 lying around and a hole in my logic module above the prom socket. Can't see why the ostrich wouldn't work, the earlier ecus are the most basic of prom setups.
I personally use 27sf512, cheap, plentiful, and have never let me down. You just need to know the offset, or double/quad/8x the cal on the chip if you're lazy. Even the socketing isn't that hard, if you're mildly skilled with a soldering iron.
My suggestion would be to pick up a later style intake and sensors and convert to 87 T2 electronics. It's not that hard to do, I believe that there's 2 or 3 sites around detailing the swap. The later setup makes things a good deal easier as far as calibrations go, too. You won't be limited to the vendors or MP cals. Not that either of those are bad at all, I ran an 85 cal from FWD for a year or so and it was quite nice. It's just that there's much more custom stuff available for 87. There are relocatable source packages available for the 87 t2 LM to do things like anti-lag, 2 step limiter, switchable boost and more.
05-10-2008, 06:30 AM
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
There are no 2.5 t2 engines all t2s are 2.2 .2.5 turbos are t1s,but can be upgraded to t2 status.
05-10-2008, 10:18 AM
My Ride: 85 GLHT, 87 ShelbyZ
We sure do. 87 New Yorker is my picture gallery for my 87 T1 suckthrough new yorker. I converted it to blowthrough so fast I didn't even take a picture of the T1 setup  As you scroll down you can see the new 89 T2 shortblock with forged pistons going in and then the TU 3" exhaust system.
converting it to blowthrough and 87 electronics. Turning the overboost function off and setting the computer controlled boost to 14.5psi made the car run 14.3. I need to do some tranny upgrades before it goes back out to the track when it opens. Should be interesting with the big exhaust, and more boost.
05-11-2008, 08:12 AM
Luckily, there are some really smart and generous people doing dev work on the ecus.
I haven't looked at the early t1 (85/86) calibrations in a while but what you can adjust may be limited as there isn't the greatest amount support for them. What you could do is get a copy of dcal from the yahoo group and look around the files section. There should be some stuff there you can use.
Stepping up to the 87 electronics is probably the best bet though, there's tons more support and much more that can be changed.
05-11-2008, 06:52 PM
The speed distance sensor?? It's on the output housing on the right side axle of the transmission. You've got to get it from under the car.
05-12-2008, 08:21 PM
#13
That's a problem. It's so stealthy I find it hard to get a race. I pretty much have to pull up and ask if they want to race  But it does make it nice when cops are around.
05-13-2008, 02:20 AM
#14
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
I'm way gonna swap to '87 electronics! Like, it's so much better & stuff!
