05-15-2008, 03:53 PM
sending unit question
My Ride: omni glh turbo
Hi there,
I have a 85 GLHT with an 88 T2 swap and other mods. Swapped out the gas tank, due to leaks and at the time, changed to a Walbro High Volume fuel pump from the stock 2 pump setup (one in tank and one in line). The problem I had was that the stock GLHT sending unit wouldn't hold the larger Walbro HV pump. I ended up using the sending unit from the new gas tank, which came out of a non-turbo 88 Omni 2.2, as it was able to hold the pump. Anyways, when I turn the key, the pump kicks on fine and I'm getting proper fuel pressure at the fuel rail (58psi). My question is, could using the 88 non-turbo sending unit cause any problems? As mentioned, I have good consistent fuel pressure at the rail, but I ran into some other mechanical problems (lost compression). I'm wondering if it could relate and/or if the change in sending units could cause a problem? Any help would be appreciated.
