Old 06-26-2008, 08:10 PM   #31
Re: I just got MegaSquirt to support our HEP signal
My Ride: '88 Horizon R/T
Engine: 2.4L DOHC
MSx/Extra EFI • Login
Post in that thread. Thanks for the support.
UnaClocker is offline
Old 06-30-2008, 11:08 PM   #32
Engine: 2.4L DOHC
Your post did the trick.. James sent me a test version. I have to add another tach input circuit to my MS before I can try it, he set it up to use both sensors. I'll let you know how it went by this weekend.
Old 07-01-2008, 07:53 AM   #33
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
I am such an influential person!
Sweet!
dyno sheet
fmic install:
crazymadbastard is offline
Old 07-01-2008, 10:46 AM   #34
My Ride: Magnum
Engine: 2.5 TII
well Is somebody running MSI with the stock distributor and the hep pickup ?
Im trying to fix my crappy idle
R/Tony is offline
Old 07-01-2008, 10:54 AM   #35
Engine: 2.4L DOHC
No, MS1 is out of development. MS2 is sooo much better..
The "Why MS2" page from my store
Old 07-01-2008, 11:48 AM   #36
My Ride: Magnum
Engine: 2.5 TII
yeah I know... but im not planning to move to MSII... if I dont have it running correctly my next step will be a 36 trigger wheel and a crank sensor, but first I want to see if somebody has it running correctly, maybe i am doing something wrong.
I will post some videos later.
R/Tony is offline
Old 07-02-2008, 05:38 PM   #37
My Ride: Magnum
Engine: 2.5 TII
Here are the videos...
As you can see my ralenti is awful, needless to say when I am acelerating the car seems like the spark is missing sometimes.
any thoughts ?
R/Tony is offline
Old 07-03-2008, 12:54 AM   #38
My Ride: '88 Shelby Z TII
videos no workie for me...
Reaper1 is offline
Old 07-03-2008, 12:29 PM   #39
My Ride: Magnum
Engine: 2.5 TII
Put the direct link to the youtube video:
YouTube - first try megasquirt video 1
YouTube - megasquirt video 2
R/Tony is offline
Old 07-03-2008, 12:46 PM   #40
My Ride: Omni
Engine: 2.2 liter 16V hybrid
Your Coolant sensor is acting like there a bad contact on. Post a Log of your engine running.
guidsm is offline
Old 07-03-2008, 01:13 PM   #41
My Ride: Magnum
Engine: 2.5 TII
k I will do that... btw what happens if I disconnect the coolant sensor while the engine is running ? If that were the problem I should see more steady rpm's ?
R/Tony is offline
Old 07-11-2008, 12:20 PM   #42
My Ride: Magnum
Engine: 2.5 TII
Im planning to move to EDIS
R/Tony is offline
Old 07-11-2008, 12:23 PM   #43
Engine: 2.4L DOHC
EDIS sucks. Plan to NEVER run spark cut?
Old 07-11-2008, 12:53 PM   #44
My Ride: Omni
thooted wheel is the way to go..not edis
guidsm is offline
Old 07-22-2008, 10:16 PM   #45
Engine: 2.4L DOHC
James Cortina, one of the two developers of the Extra version of the MegaSquirt software sent me some test code recently. Took me a couple weeks to get around to testing it, because he actually set the code up to use both the HEP sensors. I had to build a second tach input circuit in the MS. Well I tried it out tonight. Fired right up on the first try, purrs like a kitten! Can stick with the single coil/distributor setup like your used to, can do wasted spark (that's the setup I tried, with a Neon coil pack), and it will do Coil On Plug (could get 4 of those '91+ coils and hook one to each spark plug..).
It will be in the 2.0.2 version of MegaSquirt-2-Extra, which should be out real soon.
Advertising | Best Credit Cards | Loans | MPAA | Personal Injury Attorney Los Angeles
