11-08-2008, 02:06 PM
#51
Re: experiences with FWDPerformance calibrations
Mo' valves, mo' boost
My Ride: Daytona ES
Engine: 2.4L DOHC
I'm still running into some issues with my FWD Stage 5 2.4 DOHC cal. I've got the car running tons better than it was. I did the same thing as Mario03SRT as far as running static fuel pressure. I just capped off the vacuum line to my 1:1 AFPR and started tuning. Now, the car has more fuel pressure at idle which helped A LOT. Now the car starts every time. Once in a while, you'll need to feather the gas for about 10 seconds to keep it running, but after that, it's perfect. Warm starts are basically the same as cold now, which is good. Warm starts before were near impossible, making it a huge pain in the ass to go to the store or to fill up the gas tank.
However, I'm still running too rich in boost. I've got my fuel pressure down to 45psi static and it's still too rich. I only have a narrowband gauge in it right now, but my EGTs have never gone over 1450. I made some track passes last weekend and they never went over 1300. I'm running about 17-18psi on a 2.4L with 577cc (SRT Stage 1) injectors. My next step is to switch in the 527cc SRT Stage 0 injectors and see what fuel pressure works good for the car.
Turbo84voyager, I'm in the complete opposite boat as you for timing. The 2.4 needs even less timing than a fastburn 8-valve. They already did that in the calibration since it was known it would be going into a 2.4-swapped car. I set my base timing at 12 degrees when I first got the car running and I haven't touched it since.
Jon J.
1989 Daytona ES 2.4L - MPH (and, turns out, MPG too!!)
2003 Neon SXT - MPG... yeah just MPG
