Old 04-15-2003, 11:54 PM   #1
code 52, running rich
Zed
And my dawes af gauge verifies this, 2nd green light always on while idling. What are the reasons a stock fuel system would be rich? Could it have anything to do with a few charcoal canister vacuum line deletions? I had the CC removed completely from my last 2 TD's and it didnt do this.
Zed is offline
Old 04-16-2003, 01:30 AM   #2
Well on mine it was a blown FPR. I had 80+psi of fuel pressure all the time.
DarkWolf is offline
Old 04-30-2003, 07:00 PM   #3
dimik
I just had that same code on my 86 T1 it ended up being the tps
Dave
Old 05-18-2003, 03:50 AM   #4
enforcer daytona
Big vacuum leaks, bad 02 sensor and 02 sensor ground, stuck fuel pressure regulator, way to big injector, clogged fuel return, a big rock in front of you air filter
Auto Loans | MPAA | Tienda de libro | Secured Loans | Personal Loans
Page generated in 0.34612 seconds with 13 queries
