Old 06-30-2008, 06:01 PM   #1
Fuel Pressure Gauge
My Ride: Dodge Daytona
Engine: Turbo 2.2
Can someone give me some ideas where to put my fuel pressure gauge? It is not going to be in cabin, it will be outside. Would it be cool to have it peeking right outside of the hood to see it when inside? Some pics would be neat too.
Kev
Bbneon95 is offline
Old 07-06-2008, 04:51 PM   #2
Re: Fuel Pressure Gauge
I'm going through the same thing right now. I'm going to mount mine in the turbo bulge I think. I'm still considering whether or not to even have one though, but I'd like to have a permanent way to see pressure under boost. How many guys are running fuel pressure gauges??
86daytonaZ is offline
Old 07-06-2008, 05:50 PM   #3
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
best place would be right at the cowl in a pod, kinda like the old muscle cars used to do it, looks cool and you can see it while youre driving. i think you can buy hood pods for like 20 bucks or so out of jegs summit etc
do NOT under ANY circumstances install a standard fuel pressure gauge in the passenger compartment! there are types that you can install inside the car but they have a liquid filled line that runs into the engine compartment from the gauge - called an isolator. if the fittings come loose, hose breaks or the gauge itself starts to leak on a gauge that does not have an isolator you will have a 40+psi spray of fuel inside the car- garanteed fire!
crusty shadow is offline
Online Advertising | Payday Loan | Loans | Loans | Franc ehotel
Page generated in 0.27249 seconds with 13 queries
