07-23-2008, 06:34 PM
#33
Re: please help vacuum problems
Politically Incorrect
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
Sure... adjustable timing lights are nice for tuning full advance @ whatever RPM but not all that needed for setting base timing. just set it to zero on the light and adjust the distributer to get the mark you need on the bellhousing. Your gonna want to do that after you check the cam timing.
as far as the boiling... easiest first thing to do is look at your rad cap. is the rubber all old and nasty? replace it. even if the seal is ok the spring may be weak. i forget what the caps are supposed to hold but its like 15 to 18 psi - somebody will chime in on that. the point is... waters boiling point goes up with pressure. if the cap doesnt seal, water boils when it shouldn't. if the cap is sealing to the correct pressure and you still have boil-over problems... then you need to address those problems. BTW, it is normal for you to lose a little coolant during the normal course of driving, the overflow tanks are designed to let coolant go back into the radiator. if you are loosing like a quart - thats bad.
I have a feeling that there is no 'quick fix' for this car. go check/fix everything we've mentioned and we can move on to checking fuel pressure, etc.
...AND DO A COMPRESSION TEST
Click Here: I need a 2DR L-Body REAR Bumper Mount
My Mopars:
85 Shelby Charger - Garnet Red/Silver <- 100% Rust-free - Beautiful one day
86 Shelby Charger - Black/Silver <- $150 Rust-bucket Beater
73 Charger SE - Gold/White top <- Rust-free - will be MS & TT eventually
91 Spirit R/T - White <- Sacrifice to the L-Body Gods
